Applying restriction criteria to board views
When you identify restrictions in a board definition, you are, in effect, adding a where statement to the SQL query from which the definition is based. The SQL query identifies which columns are included, but the where statement reduces the number of records retrieved to include only those that meet your restrictions. This can reduce data retrieval time. However, users can, while in the Planning Worksheet, Trip Planner, or Appointment Scheduler, select Restrict and temporarily change or remove the restrictions you placed on the board definition.
When working with restriction fields, keep in mind:
All view settings are optional. If you do not select an option in a field, that restriction will not apply to the view.
To remove an entry from a specific field, highlight the entry and press the DELETE key on the keyboard.
To remove all restrictions in the current dispatch view window, click Clear. Note: Use care. The Clear button will remove all settings in the current Board Definition window, including settings in collapsed sections of the window.
A blank field has no filter effect. It is not the same as a field set to UNK or UNKNOWN, which can affect displayed data.
Applying restriction criteria to an outbound view
Follow this procedure to restrict which records will be included in an outbound board definition.
Go to File > Board Setup.
 The Board Setup window opens.
From the Board Type drop-down list, select Trips Scroll View.
From the User Tree, select the group or user that has access to this view.
From the list, select the view to modify.
Click Edit.
 The Trips Board Definition window opens.
In the header of the window, set any restrictions. Definitions are listed in alphabetical order. Field Definition Bill To Identification code assigned to the company that is to be billed for shipment To restrict on multiple Bill To companies, select each company and click the arrow.  The company ID and the company name are listed in the Selected Bill To(s) section. -
To remove a company from the selected list, highlight it and click Remove Selected.
To remove all the companies from the selected list, click Clear All.
 Booked By ID of the user who created the order Description The user-assigned name for the view. Dispatch Status The statuses identify the current phase of the order’s life cycle. -
AVL - Available The order is ready for dispatch. This status is automatically assigned to an order when it is first saved.
PLN - Planned A tentative assignment of resources has been made.
DSP - Dispatched A tentative assignment of resources has been made; the driver has been informed of this assignment.
STD - Started Resources have been assigned and the trip is in progress. This status is set automatically when you actualize the first stop on a trip.
CMP - Completed The order has been delivered. This status is set automatically when you actualize the last stop on a trip.
 Hours Back Used as a restriction when defining outbound views. This field sets the beginning time frame for which trips are to be listed. It determines how far in the past the system will go back to search for available orders. The system subtracts the number of hours entered here from the current time. Only orders scheduled to start on or after the resulting date/time are listed. For example, suppose it is currently 10:00 AM on 1/15. If 48 is entered in this field, the system will list orders that were scheduled to start on or after 10:00 AM on 1/13. Note: A zero (0) in this field indicates that the list is not to be restricted according to trips' past start dates/times. Hours Out Used as a restriction when defining outbound views. This field sets the ending time frame for which orders are to be listed. It determines how far in the future the system will search for available orders. The system adds the number of hours entered here to the current time. Only orders scheduled to start on or before the resulting date/time are listed. For example, suppose it is currently 8:00 AM on 1/17. If 48 is entered in this field, the system will list orders that are scheduled to start on or before 8:00 AM on 1/19. Note: A zero (0) in this field indicates that the list is not to be restricted according to trip segments' future start dates/times. Mileage (from/to) Distance from one location to another. Mileage can be measured from: -
Stop to stop.
First stop to the last stop on a trip, excluding miles for interim stops.
First stop to the last stop on a trip, including miles for interim stops.
 TotalMailStatus Restricts the view to include orders having the selected TotalMail status. Note: Options are defined in the TotalMailStatus label, accessed in the Edit User Definable Fields window. All options are system codes and must not be changed. Do not add options, as they will not be recognized by TotalMail.
In the body of the window, set restrictions as needed. Restrictions are organized into sections. Section names are shown in blue title bars. To open a section for editing, click  next to the section title. next to the section title.To close a section, click  next to the section title. next to the section title. Field Definition City City where the company or stop is located. Company ID TMWSuite identification code assigned to a company. LghType1-2 Categories to which trip segments are assigned for dispatch planning or pay purposes. Note: The abbreviation Lgh stands for legheader, which is another term for trip segment. Region 1/2
 Region 3/4User-defined region categories for geographic locations. Note: The names for these regions are determined by your company, as are the subgroups defined for them. Regions and their subdivisions are established in the System Administration module. RevType1-4 Revenue classifications to which a record is associated. Revenue classifications frequently are recorded for orders. Notes: -
Classifying orders allows you to track the revenue collected for different types of loads.
The names and options for these fields are user-defined. They are set up in the RevType1 - 4 labels in the Edit User Definable Fields window.
 State State where the company or stop is located. TEAMLEADER Identifies the team leader to which the resource is assigned. Note: Options are user-defined in the TeamLeader label, accessed in the Edit User Definable Fields window. Note: The View Assignment section is currently not functional.
When finished, click OK.
On the Board Setup window, click Save.
Applying restriction criteria to an inbound view
Follow this procedure to narrow down the number of records that will be listed in an inbound board definition.
| You cannot exclude shift-based drivers by means of a planning board view. |
From the Board Type drop-down list, select Inbound Scroll View.
Click Edit.
 The Inbound/Power Board Definition window opens.
In the header of the window, set any restrictions. Field Definition Bill To Identification code assigned to the company that is to be billed for shipment To restrict on multiple Bill To companies, select each company and click the arrow.  The company ID and the company name are listed in the Selected Bill To(s) section. -
 Booked By ID of the user who created the order. Carrier ID of a third party company that hauls loads. Description The user-assigned name for the view. Dispatch Status The statuses identify the current phase of the order’s life cycle. -
 Driver TMWSuite identification code for the driver. Hours Back Used as a restriction when defining outbound views. This field sets the beginning time frame for which trips are to be listed. It determines how far in the past the system will go back to search for available orders. The system subtracts the number of hours entered here from the current time. Only orders scheduled to start on or after the resulting date/time are listed. For example, suppose it is currently 10:00 AM on 1/15. If 48 is entered in this field, the system will list orders that were scheduled to start on or after 10:00 AM on 1/13. Note: A zero (0) in this field indicates that the list is not to be restricted according to trips' past start dates/times. Hours Out Used as a restriction when defining outbound views. This field sets the ending time frame for which orders are to be listed. It determines how far in the future the system will search for available orders. The system adds the number of hours entered here to the current time. Only orders scheduled to start on or before the resulting date/time are listed. For example, suppose it is currently 8:00 AM on 1/17. If 48 is entered in this field, the system will list orders that are scheduled to start on or before 8:00 AM on 1/19. Note: A zero (0) in this field indicates that the list is not to be restricted according to trip segments' future start dates/times. INSTATUS Status of the tractor’s next trip. Statuses are: -
DSP - Dispatched Tentative assignment of the tractor has been made; the driver has been informed of this assignment.
PLN - Planned Tentative assignment of the tractor has been made.
UNP - Unplanned Tractor has not been assigned to a future trip.
 Tractor ID assigned to the tractor TrlStatus Statuses that identify the trailer’s current activity level. Trip-related statuses are: -
AVL - Available Trailer is not on an active trip, has not been assigned to any future trips, and does not have an active expiration.
PLN - Planned Trailer has been tentatively assigned to a trip.
DSP - Dispatched Tractor has been tentatively assigned to a trip; the driver has been informed of this assignment.
Use - In Use Trailer is assigned to a trip that is in progress. Statuses also may be used to identify expirations. A number of statuses come pre-loaded with the system; they are called system codes. Others are user-defined in the TrlStatus label, accessed in the Edit User Definable Fields window. Commonly used expiration-related statuses are:
OUT - Out of Service Trailer is disabled and should not be used on a trip.
VAC - In the Shop Trailer is undergoing maintenance and should not be dispatched on a trip.
In the body of the window, set restrictions as needed. Restrictions are organized into sections. Section names are shown in blue title bars. To open a section for editing, click  next to the section title. next to the section title.To close a section, click  next to the section title. [.underline]# # next to the section title. [.underline]# # Field Definition CarType1-4 User-defined carrier categories to which the carrier is assigned. Note: The field name and options are user-defined in the CarType1-4 labels, accessed in the Edit User Definable Fields window. City City where the company or stop is located. COMPANY Commonly used to identify a subsidiary within your organization. The exact meaning is dependent on the type of record. -
For a resource, an entry in this field identifies the company with which the resource is associated.
For an order, an entry in this field identifies the company that is responsible for completing the order.
 Note: The field name and options for this field are set up by your company in the Company label, accessed in the Edit User Definable Fields window. Company ID TMWSuite identification code assigned to a company. DIVISION Commonly used to identify the segment of your organization with which the resource is associated. Note: The field name and options for this field are set up by your company in the Division label, accessed in the Edit User Definable Fields window. DOMICILE Resource’s home location. Note: The options for this field are set up by your company in the Domicile label, accessed in the Edit User Definable Fields window. The field name itself is hard-coded and cannot be changed. DrvType1-4 Driver classifications to which the driver has been assigned. Note: The name and options for these fields are user-defined in the DrvType1 - 4 labels, accessed in the Edit User Definable Fields window. Assignment of drivers to driver classifications allows you to track the revenue collected for trips assigned to those drivers. In some cases, such classifications may also govern the pay rates used to determine driver settlements. Fleet Fleet to which the resource is assigned. Note: The Fleet options are user-defined in the Fleet label, accessed in the Edit User Definable Fields window. LghType1,2 Categories to which trip segments are assigned for dispatch planning or pay purposes. Note: The abbreviation Lgh stands for legheader, which is another term for trip segment. Region 1/2
 State State where the company or stop is located. TEAMLEADER Identifies the team leader to which the resource is assigned. Note: Options are user-defined in the TeamLeader label, accessed in the Edit User Definable Fields window. TERMINAL Terminal location with which the resource is associated. Note: Options are user-defined in the Terminal label, accessed in the Edit User Definable Fields window. TrcType1-4 User-defined tractor categories to which the tractor is assigned. Note: The field name and options are user-defined in the TrcType1 - 4 labels, accessed in the Edit User Definable Fields window. TrlType1-4 User-defined trailer categories to which the trailer is assigned. Note: The field name and options are user-defined in the TrcType1 - 4 labels, accessed in the Edit User Definable Fields window. Note: The View Assignments and Additional Filters sections are currently not functional.
Applying restriction criteria to a shift view
Follow this procedure to restrict which records will be included in a shift board definition.
| Restrictions on a shift view are set for the shift driver. |
From the Board Type drop-down list, select Shift Planner Scroll.
From the user tree, select the group or user that has access to this view.
From the list, select the view you want to modify.
Click Edit.
 The Board Definitions window opens.
On each of the sub tabs, set restrictions as needed. Note: For field definitions, see Drivers.
When you are finished, click OK.
Applying restriction criteria to an Appointment Scheduler view
Follow this procedure to restrict which records will be included in an Appointment Scheduler view.
From the Board Type drop-down list, select Appointment Scheduler Scroll.
Click Edit.
 The Appointment Filters window opens.
In the body of the window, set restrictions as needed. Field Definition Bill To TMWSuite identification code assigned to the company that is to be billed for shipment. To restrict on multiple Bill To companies, select each company and click the arrow. The company ID and the company name are listed in the Selected Bill To(s) section. -
 Status The dispatch status of an order. Priority The dispatch priority to be given to the order. The system code options available from the drop-down list are: -
High Priority
Medium Priority
Low Priority
 Your company may wish to add additional priority options using the OrderPriority label in the Edit User Definable Fields window. Appt. Status The appointment status of a stop. Options are: -
C - Customer makes own appointment.
N - No appointment required.
R - Needs to be rescheduled.
_S _ - Needs to be scheduled.
_SCH _ - Scheduled.
 Date/Time Filters  Stop Filters  -
Region 1-4 fields - user-defined region categories for geographic locations. Note: The names for these regions are determined by your company, as are the subgroups defined for them. Regions and their subdivisions are established in the System Administration module.
Stop Types - options are to restrict trips by either pickup or drop stops.
 Order Filters  Revenue classifications to which a record is associated. Note: The names and options for these fields are user-defined. They are set up in the RevType1-4 labels in the Edit User Definable Fields window. Shipper/Consignee Filters
Applying restriction criteria to a resource scroll view
Follow this procedure to restrict which records will be included in a resource scroll board definition.
From the Board Type drop-down list, select a resource scroll view.
Click Edit.
 The Board Definition window opens.This example shows the Board Definition window for ScrollCompany view.
On any of the restriction tabs, select the appropriate restrictions.
Click OK.
